Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SweetHome3d shut down after some seconds » » » » Post: Re: SweetHome3d shut down after some seconds |
Print at Aug 1, 2010 9:25:13 AM |
| Posted by Puybaret at Jun 11, 2009 1:03:00 PM |
Re: SweetHome3d shut down after some seconds One of the differences between the installer/Java Web Start version and the Jar executable version is the max amount of memory required by Sweet Home 3D to run. Please, run SweetHome3D-2.0.jar with the following command (use Windows Start menu > Execute dialog box and replace "C:\path\to\" by the exact location where SweetHome3D-2.0.jar can be found): javaw -Xmx512m -jar C:\path\to\SweetHome3D-2.0.jar then with the following command: javaw -Xmx1024m -jar C:\path\to\SweetHome3D-2.0.jar and report here if both commands worked correctly. Thank you for your help. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
Current timezone is GMT Aug 1, 2010 9:25:13 AM |
